Скрипт создает и конфигурирует EAPS домен, конфигурирует EAPS и control vlan, добавляет protected vlan и включает EAPS. Изменив под свою сеть, скрипт даст возможность быстро разворачивать EAPS кольца на сети и менять их настройки.
Скрипт:
enable cli scripting
# @METADATASTART
#@DetailDescriptionStart
# Script : EAPSConfig
# Revision : 1.1
# Last Updated : April 4, 2008
# Purpose: This script provides an example of Ethernet Automatic Protection
# Switching (EAPS) for an ExtremeXOS™ switch. In this example:
# 1. An EAPS domain is created and assigned a name
# 2. EAPS is configured for the switch
# 3. EAPS control VLAN is configured
# 4. EAPS control VLAN is added to EAPS domain
# 5. Optionally, EAPS protected VLAN is configured and added to EAPS domain
# 6. Optionally, EAPS is enabled (switch and domain)
# Note: The EAPS domain name must begin with an alpha.
#@DetailDescriptionEnd
# EAPS Variable Definitions
# @VariableFieldLabel «If this script encounters errors, do you wish to abort or ignore?»
set var clierrormode abort
# @VariableFieldLabel «Create a new EAPS Ring? (yes or no, switch must be part of EAPS)»
set var yneaps yes
# @VariableFieldLabel «Will this switch be a master or transit? (master or transit)»
set var eapsMT master
# @VariableFieldLabel «Name of EAPS domain»
set var eapsdomain e1-domain
# @VariableFieldLabel «EAPS Primary port number»
set var eapsprimary 23
# @VariableFieldLabel «EAPS Secondary port number»
set var eapssecondary 24
# @VariableFieldLabel «Name of EAPS control VLAN»
set var eapscontrol ecvlan
# @VariableFieldLabel «Tag for EAPS control VLAN»
set var eapscontroltag 4000
# @VariableFieldLabel «Add the VLAN you are connected to currently? (yes or no)»
set var yneapscurrent yes
# @VariableFieldLabel «Name of VLAN you are on now?»
set var eapscurrent default
# @VariableFieldLabel «Enable EAPS on the Switch? (yes or no)»
set var yneapsenable yes
# @MetaDataEnd
# Create an EAPS Domain and Add Control and Protected VLANs to the EAPS Domain
if (!$match($clierrormode,ignore)) then
configure cli mode scripting ignore-error
create log entry «CLI mode set for Ignore on Error»
else
configure cli mode scripting abort-on-error
create log entry «CLI mode set for Abort on Error»
endif
if (!$match($yneaps,yes)) then
create log entry «Starting EAPS Configuration on Switch»
configure eaps config-warnings off
create eaps $eapsdomain
configure eaps $eapsdomain mode $eapsMT
configure eaps $eapsdomain primary port $eapsprimary
configure eaps $eapsdomain secondary port $eapssecondary
create vlan $eapscontrol
configure vlan $eapscontrol qosprofile qp8
configure vlan $eapscontrol tag $eapscontroltag
configure vlan $eapscontrol add port $eapsprimary tagged
configure vlan $eapscontrol add port $eapssecondary tagged
configure $eapsdomain add control $eapscontrol
create log entry «Finished EAPS Configuration on Switch»
endif
if (!$match($yneapscurrent,yes)) then
configure vlan $eapscurrent add port $eapsprimary tagged
configure vlan $eapscurrent add port $eapssecondary tagged
configure $eapsdomain add protect $eapscurrent
create log entry «Default VLAN added to EAPS domain»
endif
if (!$match($yneapsenable,yes)) then
enable eaps
enable eaps $eapsdomain
create log entry «EAPS Enabled on Switch»
endif
